I'm pretty sure that this isn't good..shouldn't be a radish clay color.. put of 08 zx6r
I'm not an expert but sure as heck not a novice...but your tank and injectors have left the chat. Clean your tank and injectors..clean those plugs . You should feel a differenceView attachment 111130 View attachment 111131 I
I've been running vp madditiveRust?
Fuel additive?
and it is running rich, IMO from the view you show, show deeper down inside the electrode insulator cavity- and better focus!!
Does your bike have O2 sensors or a cat??????????? (I do not see where you listed which year bike you have)I've been running vp madditive
Been there..clean the fuel pump housing with baking soda and vinegar. I thought my fuel pump died. Put in. A new cheap one and that one didn't even last a couple tanks till it started acting up..didn't line the tank after decreasing and rust blasting but it helped all the way. Put the Mitsubishi pump back in with the correct fuel pump regulator and made sure the o-rings were where they're supposed to be. She screams all the way to 16,500..I'm not even able to whole shot in 1st gear without hesitation..my first bike under my ownership..just took my yoshimura slipon off. I feel a difference. Don't like riding around with no plates or brake lights and signals when the yoshimura is missing the stock brackets..I'm glad our 08 doesn't have o2 sensors..atleast my version . Things can't be astray tho for maps to work..atleast o2 sensors can adjust on their own if things are off with plugs and ports and other stuff..So maiden run today. Bike won't want to get above 8grand in rpms. I noticed that the vacuum hoses connected to all 4 carbs wasn't connected so I ran a hose up to the sensor above the airforce box and I might have it in the wrong sensor. I just unplugged that hose I'll start it up here shortly... also Bike is an 08
So I just took the airbox off.. I had a vaccum line from the carbs to the sensor on the airbo(big mistake) also ran a line from pcv to vaccum gauge as an experiment (bigger mistake) so I took those off and buttoned it up the way I found it... also realized that I didn't have the airbox mounting bolts applied and two hose clamps that sinch the secondary injectors boots on the throttle bodys.. I changed the fuel lines to oversized gauge and that was a big mistake I feel so im.gonna salvage the original line and hope for the best.. this is what I have so far... and so what exactly do I need to do with the pump ? I love the 08 this is such a sweet bike.. the new clutch feels good though along with the new asv lever I installed.. sucjs I can't get the master cylinder with the advanced front brake to hold a pressured system.. must be the line won't adjust straightened enough or the mc is leaking.. idk suzks thoughBeen there..clean the fuel pump housing with baking soda and vinegar. I thought my![]()
Get a master cylinder rebuild kit. OEM.So I just took the airbox off.. I had a vaccum line from the carbs to the sensor on the airbo(big mistake) also ran a line from pcv to vaccum gauge as an experiment (bigger mistake) so I took those off and buttoned it up the way I found it... also realized that I didn't have the airbox mounting bolts applied and two hose clamps that sinch the secondary injectors boots on the throttle bodys.. I changed the fuel lines to oversized gauge and that was a big mistake I feel so im.gonna salvage the original line and hope for the best.. this is what I have so far... and so what exactly do I need to do with the pump ? I love the 08 this is such a sweet bike.. the new clutch feels good though along with the new asv lever I installed.. sucjs I can't get the master cylinder with the advanced front brake to hold a pressured system.. must be the line won't adjust straightened enough or the mc is leaking.. idk suzks though View attachment 111234
