While that looks good, I have different plans. If I get to the point where I want a dedicated set of plastics for the track, my plan is to make them out of fiberglass using my current fairings as a template. I also only need the left rear fairing to have a full second set regardless.You basically want to replace the back seat for a trackday with a fiberglass cowl?
Could I recommend this instead: buy a replacement undertail/battery tray. With a jigsaw cut off the 'carbon fiber look' parts, leaving the battery tray and ecu mount, reinstall. Use an ArmorBodies or similar Superstock Race tail - exactly what you want (you have to trim the sides off the undertail to get the fiberglass tail to fit), and you can then mount a foam block backrest.
You'd then switch between the setups (yes, moving the battery tray, battery, ECU, and starter solenoid before/after trackdays).
Here's what I mean:
View attachment 114042 View attachment 114043 View attachment 114044 View attachment 114045 View attachment 114046
I didn't bolt the race tail on for the photo so it's kinda dipping down under the seat, but you get the idea.
I don't want to cut up another seat tray, and having to switch out all of that just to go to the track seems like way more work than it's worth for me.
My seat cowl idea is more for looks; the function is a minor payoff that probably isn't very necessary.
