I figured that because they don’t make them that thick there’s a reason I have that kinda clearance issues. The intake valves on the same cylinder are bent as well but not to this extent The guy I bought the engine from said it had a timing chain issue. I did check the piston height just to make sure there isn’t a bent rod that part checked out glad I didn’t put this in and try to run it
