Let me make a couple corrections to the above statement...........
OEM shims from any OEM dealer that comes from the manufacturer ( Honda, Yamaha, Kawasaki, Suzuki, Triumph, Ducati to name the for sures....) are hardened steel all the way through! Yes OEM 7.5 mm shims from any of the manufacturers fit all the other manufacturers 7.5mm shims, as will the 9.5mm, 13mm, 20mm, 25mm etc---they most certainly are all made at one plant and then sold to the oems.........
Yes OEM HONDA shims do cost about 60% of what OEM KAWASAKI cost, and the only time you will be forced to buy OEM KAWASAKI at the higher price is when you need shims larger thickness than 2.95mm, so yes absolutely do yourself a favor and buy brand new shims from the Honda dealer!!!
always brand new!!!!!!!!!!-- why brand new, I have zero doubt dealership bean counters have them buying the same chineseum garbage to put in bikes for the unknowing and uncaring and they throw the shitty chineseum back in their bin of shims to be reused multiple times -dented and all with zero fucks given........... product of greed and stupidity and idiots who do not care about your motorcycle!!!
The shim "kits" you buy online (all of them!!!!!!!) are shit quality surface only hardened (usually to .001" or less of hardness and not even that hard) garbage produced in China made from chineseum garbage trash steel, they are super soft in the middle and rarely are the diameter they represent nor the thickness they claim----------- CHINESEUM TRASH is to be refused and never used for any and all reasons!!!!!!!!!!!!!!!
DO NOT SUPPORT CHINA!!!!!!!!!!!!!!!!!! the oems like Kawasaki, Honda, Suzuki, Yamaha and Triumph have and will reject warranty if they find non oem shims installed as they know the chineseum trash doesn't work and have casued valve train issues
There is the right process to harden the shims all the way through on good tool steel---OEM shims made in Japan..........
then there is the substantially cheaper process to surface harden only over shitty quality steel----- everything chineseum trash!!!!!!
