i used 05 forks which gets rid of the need for spacers on the calipers like you need for 03-04 forks
you will have to swap over to 05 calipers since the forks are set up for radial mount calipers
i had to use 00-02zx6r or 05-08zzr600 wheel spacers
both front ends use the same axle
and i had to press the stem out of my triples and press it into the 05 triples.
all that is with the 98 front wheel i have recently swapped to newer wheels
you'll need diff clip ons and they will interfere with the ram air covers but you can run cbr1000 clip ons and it should fix that
you lock cylinder will need some massaging to work with the top triple but it didnt matter to me when i did the swap cuz i moved the ignition and shaved the mount off
with enough lookin you can get the whole front end fairly cheap and other than the stem swap its all simple bolt ons
wonderful people, please help..........
I have a 97 zx6r, and due to multiple reasons, had to move engine onto 98 zx6r frame..
I have encountered obvious problems, but my issue is this
how on earth do I get my 97 forks to fit onto the 98 frame??........ I have a new tyre, brakes and rim on the 97... the 98 has broken calipers bent rim etc etc etc(prefer not to use it)
the stem is shorter than 98 stem..
help
help
help
help
