1 - 7 of 7 Posts
I'm off to the South of France this summer on my 04 plate 636. We have a track hired down there. Now i have ridden my mates 07 zx6r and the brakes were so much sharper. Will theses brakes fit my 04 bike? If not, what other options do i have? Thanks
yep the brake caliper will fit but you need the master cylinder too , brake lever ect, you could do it cheap and just use a different master cylinder with a better ratio
yes swordfish, the upgrade can be done because i am also doing it. the parts that you need are 07-08 zx6r or zx14r nissin calipers, 05-08 zx6r rotors, but you will also need 10mm spacers and 10x70 bolts for your forks or (05-08 zx6r front forks, but that can be a little expensive for the calipers to fit onto the larger size rotor). last but not least you will need 05-08 zx6r radial master brake cylinder which makes alot the the difference in braking force. good luck with your upgrade, all parts can probly be found on ebay.
so why cant ya just change the calipers and leave the rest?
1 - 7 of 7 Posts
