Hey forum members. Im looking for some input, I finally got my bike almost road ready but hit a problem. My Bike had been sitting all winter while i had done work to it, New tires, new sprockets, new fluids, valve adjustment, plastics repairs, etc. When i put the bike on the stand the front brakes worked before we bled brakes and put new brake fluid in we noticed the brake had no pressure. Also figured that after putting in new fluid and bleeding problem would be fixed, but to no avail bled correctly pumping 5-8 times and holding lever in while bleeding. Started at master cylinder bleeder nipple then went to calipers using the same pumping methods. The front brakes do not grab at all or have any pressure. I was thinking about rebuilding both mc and calipers but after that it would be about 100$ so i was debating an doing an upgrade? If that were the route what would you guys recommend, which braking systems are the most compatible with a 06 636 as well as get the best reviews? thank you for you input!
