Hi guys i have a 2002 zx6r a1p and i have an idle problem and slight missfire at low revs?? Mid range revs and high revs are fine,
I have checked the spark plugs and they seem fine also i have cleaned the carbs and set the mixture screws to 2.5 turns also cant seem to find any vacuum leaks and compression is fine also i have checked the battery and the engine off and engine running voltages are fine...
Im stumped as it needs revs drop to 1000rpm and then bounce to 1400rpm sometimes and i have adjusted the idle when the engine is warm and its still unstable...
Any help appreciated...thanks guys
