:bitchslap:It is mostly preference. But average seems to be 32 front and back.
Ouch!:bitchslap:
Yeah, that's max pressure for maximum load capacity. I would never run a sportbike rear tire at 42psi , unless you are carrying a 200lb passenger.:dowhat
Interesting. I have always used what was on the swingarm for street riding. Most tire manufacturers always suggest to use OEM pressures also. It seems strange that they wouldn't give you the recommended standard pressure and max then.Yeah, that's max pressure for maximum load capacity. I would never run a sportbike rear tire at 42psi , unless you are carrying a 200lb passenger.:dowhat
What if you are the 200lb passenger.. :dowhatYeah, that's max pressure for maximum load capacity. I would never run a sportbike rear tire at 42psi , unless you are carrying a 200lb passenger.:dowhat
I still wouldn't run 42psi..unless your had another 150 lb passenger on there with you.What if you are the 200lb passenger.. :dowhat
Why would you want the max PSI if you are not loading the tires to the max load rating? Higher pressure is just going to wear out the center of your tire faster and possibly keep your tires from coming up to optimal temp quickly. I agree you should run higher pressures on the street than the track, but not max psi listed on the tire.Use max psi listed on tire for street riding. Track riding is another story...
Sorry....failed attempt at sarcasm :laughI still wouldn't run 42psi..unless your had another 150 lb passenger on there with you.
Keeping your street tires inflated as recommended will reduce wear and prolong the life of the tires. That is because a low pressure, tire gets to a higher temp and wears them much faster. This will give better grip, but for street riding it's not necessary. now if you decide to ride out to the canyons, then by all means drop the PSI *ssome*. It's very rare anyone will push their tires beyond its grip on the street if your doing it right.Why would you want the max PSI if you are not loading the tires to the max load rating? Higher pressure is just going to wear out the center of your tire faster and possibly keep your tires from coming up to optimal temp quickly. I agree you should run higher pressures on the street than the track, but not max psi listed on the tire.
If you have them inflated to the max tho, you are going to wear out the middle more because you aren't squishing them down as much (instead of distributing the wear of the throughout a larger section of the tire, you're putting it all in a small band in the middle). If you don't have it loaded to max, you shouldn't have it inflated to max.Keeping your street tires inflated as recommended will reduce wear and prolong the life of the tires. That is because a low pressure, tire gets to a higher temp and wears them much faster. This will give better grip, but for street riding it's not necessary. now if you decide to ride out to the canyons, then by all means drop the PSI *ssome*. It's very rare anyone will push their tires beyond its grip on the street if your doing it right.
Dunlop recommends 32 psi front/30 psi rear for the Q3's. Those are the pressures I run on the street and on the track, and I usually get 8K - 10K miles out of a set. Maximum pressure is only for maximum weight. If you run maximum pressures without the extra weight, you are more likely to slide around when braking (especially the rear).Interesting. I have always used what was on the swingarm for street riding. Most tire manufacturers always suggest to use OEM pressures also. It seems strange that they wouldn't give you the recommended standard pressure and max then.
