1 - 2 of 2 Posts
So I went ahead and ordered the HID kit from TRS. All of the components look great and high quality. I do have a question I haven't been able to find an answer to. The Motorcycle Stage I kit comes with a wire harness that has a three spade connector that is supposed to plug into the bikes headlight relay. Well apparently on my 2000 ZX6R the headlight relay is incorporated into the Junction Box. So pray tell how is one to wire this guy up??
I'm not familiar with the 2000s but if the harness has spade connectors then you need to t-tap into the oem harness for the power/ground/and a activation wire. If you don't know what wires are what check the schematic in the FSM.
Alternatively your could set up your own relay using the same reference wires. 12 volt power/ground can be taken from anywhere in the harness. You will just have to find a good switched igniton wire.
1 - 2 of 2 Posts
