1 - 20 of 53 Posts
Switching to slicks after my Q4's are worn.
Considering 2000w generator. Would that be sufficient?
Also, any benefits from using dual temp vs single?
A 2000w is fine, and that is what most people run. Warmers only require about 700-1100 watts on average i'd say. I got some dual temp chicken hawks because I got a smoking deal on them and figured I could use the low setting for rain tires. Then I found out you don't need warmers for rains lol. So I'll just use the low setting if I have a long gap in between races so they don't go cold. One drawback is I've forgotten a couple times that it was on low, but low is like 135 degrees vs 175 degrees for high.
Sent from my LM-X410.FGN using Tapatalk
Director of Moderation
Woodcraft or Chicken Hawk dual temp warmers. Yes a 2000W genny will be enough.
What is the low temp setting for?
I've seen reference of using low temp on more street oriented tires, but most of this was anecdotal from different forums and FB, etc. Opinion seems to be tires like that get greasy at high temp, although I have a hard time believing it's from the tire warmer and not from running them hard on the track.
I just got dual temp warmers this year(because I got them for more than 50% off), I plan on trying high and low setting on a set of Q3 that are 50% life left just to see what happens.
Any of the name brands are good. The new Vortex warmers with digital adjustment are cool, but now I’m using woodcraft’s which I really like because of the auto shut off feature. Low temp is useful for racing mainly, but if you’re at a trackday and want to keep your tires on low before lunch because you’re going right out after then it’s useful. Single temp I wouldn’t like because you’re stuck with no options. I pretty much keep my tires warmed on low or high at all times during the day lately, only turn off if It’s going to be more than 1-1.5 hours between riding. Better to not heat cycle
Street tires can’t hold super high heat like a racing slick but yeah that’s pretty much just anecdotal BS. Reason is that unless you’re a pretty fast guy the tire is probably going to have a lower temp on track than a warmer on hot setting anyways
if you have ever measured the actual heat in the tire on a dot street tire at a trackday event..... Well there are tons of variables!!!
~ but I have measured it on numerous tires from numerous riders and it is very common to only see 115*-135* surface temp(slower riders to faster riders) on them immediately entering the pits (now mind you if you were at some event with ambient temps over 100* and a bright sunny day- these same riders could find their temps higher)
So most those warmers even on the low setting of 135* is warmer than they will typically see on the track
And yes, street tires are made to work within ~5% of their optimal traction limits in a wide- albeit low- temperature range like one would encounter on the street - less than 130* tire temp
When you start getting them over about 145* they do start falling out of that peak performance range, get them in the 160* and they are getting sketchy, take them into the 170's or 180's you may as well start throwing hundred dollar bills out the truck you hauled it there with, while driving down the freeway............because your medical and repair bills will be huge unless you just give up riding and putt around til they cool back off
the highest I have ever seen DOT's run when I ride is 138* and that is riding at a decent pace for about 30 minutes straight.......... most of the time when I have checked they are closer to 132* (20 minutes sessions is typical)
on the street the same tires vary wildly depending on the road, but 105-120 is very common when I have measured in typical 70*-85* ambient temps
Easiest thing to do is physically measure them!
and just as a side note to the warmers- it typically takes about 45-60 minutes to actually get the tire fully warmed to the warmer setting when you first put them on
between sessions one can simply leave them on the low setting and keep them about 135* (from 135* is takes about 20 minutes to get back to 175*....atleast here in the great white north that has been the norm when ambient temps are 70's-80's)
I am not sure you can really go too wrong with any of the dual temperature units that are not made in china or some other 3rd world nation shithole.... they all have their limits though and abuse/neglect shortens life significantly
Dual temps are neat, but not all that useful in my book.
Rains don't require them, and if they do, are your tire warmers water proof? Oh...you didn't think about the scenario when you come back into the pits and the entire bike is wet? Interesting...
People talk about the low setting so you don't 'bake' your tires over lunch or whatever...if the tires are designed to operate at that temperature, and the warmers keep them at that same constant temp...what are you "baking", exactly?
The more shit the warmer has, the more shit can go wrong with it. Love my Capit's. Single temp, no switches, no theromstats, and not that I need it, but they're waterproof as well. Woodcraft's are really nice as well, but I'd like them more if they were single temp only. I've had the switch bumped more than once and didn't notice until the warmer was coming off and I was about to go out on a luke warm tire, with a pressure I couldn't really set because it wasn't up to temp.
Slightly off topic, but what were your thoughts on the Q4's?
Did you ever get rid of the "wobble" you mentioned in the tire thread?
What made you jump to slicks for the next set?
Discussion Starter #13
Q4's are good but slicks are almost the same price so it doesn't make sense to keep buying them for a track only bike.
The wobble was due to tank cover fairing interfering with the alignment of the steering damper so I switched to the graves ohlins damper.
I’ve been running Q4’s over this Winter/Spring trackday season here in AZ. I love them and feel more confidence with them than the Q3+, however they wear out REALLY quick! At least the rear does... i’m a B+/A- pace rider and i’m really lucky if I get three days out of a rear. I’ve actually been having the problem where on the third day I feel like I need to change the rear mid-day, so that adds a level of irritation since one shouldn’t have to waste track time getting tires changed, in my opinion. On the Q3/Q3+rear I could always get through “one more day” if I had to.
I’m starting to consider the switch to slicks, however, i’m lazy ... and don’t want to dick around with the warmers and generators.... Also, physically obtaining the slicks is more difficult than buying a set of Q4’s. One other factor that I struggle with is that at my riding pace I don’t think slicks will be kept within their optimal temperature. It doesn’t make sense to me to use race tires if they are not hot enough to give you race traction, because of one’s lack of ability. The Q4 doesn’t seem to have that problem.
^This. Except for 1-1.5 hours is nothing. I've heard people talk about "baking" a tire while leaving the warmers on, but I haven't experienced any of that and during race weekends I often leave mine on high for like 3 hours straight. They're nice and hot for my next race then :D
I like the dual-temp Woodcrafts, but honestly I only use the low setting like 5% of the time maybe. If there is time I'll use the low setting on rain tires. I know it's not needed, and by the end of the warm-up lap they're probably at the same temp as without the warmers, but it gives me more confidence. I guess it's a mental thing...maybe that's why so far I've always had good pace in the rain lol
Other than that I'll sometimes use the low setting if it's really cold in the morning (like in the 40s). I don't want to "shock" the rubber too much and heat it too fast, so I'll put them on low for about half an hour and then turn it to high, so the temperature ramp rate is a bit slower.
Reactions: Todd and jd41
Cooking the tires makes them lose grip because the oils come out. So no bueno. Also you’re not supposed to run warmers on rain tires
I haven't seen any oil come out from any of my tires, ever! Even after leaving them on the warmers for longer periods of time. About the use on rains...thanks...see comment above in bold lol
Reactions: Gawernator
How are you going to cook something by leaving it at a temperature it's designed to operate at?
1 - 20 of 53 Posts
