Dunlop Q4 Front / Q3+ RearWhat kind of tires are you running?
So DOT tires that specifically call for no use of warmers and zero benefit from warmers other than in your head......Dunlop Q4 Front / Q3+ Rear
Well you show vortex tire warmers in your picture and the lowest setting according to Vortex is 140*f..but when I have tested them actually in use they have always been above 150*f...In general, I have been very skeptical of tire warmers. Even when I raced. But, I was always on the west coast with much warmer weather. Not the extreme weather we have in Texas.
I share a paddock with the Dunlop tire distributor at the track. When I spoke to him about it. He said, yes, you see all the guys that race use the tire warmers with DOT tires, summer and winter. The key they figured out is to get a set of warmers that have an low adjustable range because 120 degrees is the maximum you want for the Q series tires. The race slicks take 160 to 180 degrees and that would destroy the Q series tires. SBT had a set on sale so I thought I would check it out. Regardless of everyone's thoughts or opinions, going into turn 1, first lap there is always a little movement from the tires. Not the case with when using the tire warmers. Is some of it in my head absolutely, because you cant argue with feel. Used properly with DOT tires, warmers work great.
Kids regardless of any opinions you see here, always consult your local track tire distributor to help you make your decision.
Wait, what? You are running tire warmers on street tires?Dunlop Q4 Front / Q3+ Rear
I didn't see your reply until I had put everything away after riding yesterday. I only had time to take quick picture. It would have been better to make a video of the warmers on the bike and the control unit operating. Pictured below is the single control unit that manages both tires independently. You select Front or Rear and dial in the temp you want for each with the arrows The adjustable range of the tire warmers is 32f – 210f (I set them both at 122f). Once set, you watch the temps go up to the desired tempter. Once it reaches the set tempter it fluctuates 1 to 2 degrees above and below your setting. Once I take off the warmers, I use a tire temp reader (I think it's made by "accutech") that pierces the tire about 3mm or so. I've been getting readings between 118f and 122.5f.
After 2 days at the track and 14 (30min) sessions using the warmers, I've cooked a rear tire and the front still looks pretty decent. Which is typical for non-tire warmer use as well.
Vortex Dual Temp Tire Warmers (Had to call Vortex to get the adjustability range before purchase)
https://www.sportbiketrackgear.com/...vE8egVL0COmtvcJr6ydgbzFKSUo2KQDBoCR7MQAvD_BwE
You sir are absolutely right. I see that now as well. The pictures online at STG do not show the control unit or the proper warmers. The warmers in my pic below fit a little better and they also have a thick elastic mesh to help insulate the tire and wheel. (See pic below red circle area). The part number is correct though (TW101 ). That link was text to me by a my friend who has these warmers already and also pits in our garage with a ZX6 as well. I just followed the link, made sure the part number was right and clicked "buy".I have never seen a tire warmer you could set that low. so that is interesting you say you can set it that low
the linky you provide is just their standard 2 position set up of 140* or 180* (but they run atleast 10* hotter than that in my experience) and that is what they show on their own website too (and the control box looks identical to what you show)
Dude parking on the Fire lane...
I asked track management about that. They said, "your pitting, not parking, no worries". Umm ok.Dude parking on the Fire lane...
