1 - 10 of 10 Posts
Can you go into further detail with that? Is the engine cold/warm, are you blipping the throttle or trying to accelerate, maybe a video?
Sounds like a float is stuck,? but I'm no expert on the 02 carbs. ( or any bike for that matter) ha. Quick check is take a wrench and tap along the carb, sometimes that will drop the float back into the bowl.
well, it starts up and it'll run all day long if i let it, but once i give it gas and get the rpms above 2k it dies. I put a brink knew fuel pump and fuel filter, and checked the airflow. I don't know much about bikes are where things are located on it for that matter.. But, i was thinking carbs, but I'm not sure how to clean them or anything
Sounds to me like a main jet clog. If it idles fine then the pilot jets are likely clean.
Disassemble... clean jets... reassemble. Vroom vroom? :O
get a copy of your service manual and have a look at carb disassembly.
1 - 10 of 10 Posts
