1 - 20 of 30 Posts
If you don't have a rear stand, they serve no purpose.
I would have to disagree. Get ones that are also meant to serve as crash protection for your swingarm. I had a low-side to the left and my spool took the brunt of the damage back there. Had they not been there, I don't see how my swingarm would have made it through without getting jacked up.
I have the large, delrin abs spool sliders and they serve as crash protection for my swingarm. Also, it would be a pretty good idea to invest in a set along with a rear stand.
Kawasaki Ninja ZX6R 2009-11 Woodcraft 10mm Swingarm Slider Spools:Amazon:Automotive
I had the spools with sliders on my last bike, the dug in and snapped on a lowside. So I guess it comes down to the same old sliders vs no sliders debate.
And yes, my swing arm ended up scratched any way, and had a broken tab from the slider
I used to leave my vortex spools on for convenience of using a rear spool stand but they ripped off my swingarm mount in a high side. Now I have to use the swingarm lift adapters on my pit bull stand which are a bit sketchy.
In a lowside crash, I had swingarm slider spools on it and it saved my swingarm from being scratched. But in a highlife crash I had, it got ripped off on the other side. I got it welded back on for like 60 bucks but I had to bring it to a special person that welds aluminum. I don't ride with them on anymore.
If you are not going to use them for a rear stand, there is little to no point in having them as far as I'm concerned.
exactly.
The after thought of the provisions and how they are on the outside of the swingarm on most models will do more harm than good if you have some sort of "crash protection spool slider".
IF you were going slow enough that the swingarm spool did its job and kept the bike off the ground I would argue that in the same scenario damage wouldn't have occurred to the swingarm without the spool.
However, in a legit crash I have seen the mounts for the spools snap completely away from the swingarm and the same exact thing that was supposed to protect your swingarm is now the cause of you having to replace it.
IF you are running spools get the smallest spools possible to limit how far they stick out which creates more leverage on the threaded provision in the swingarm.
Discussion Starter · #19 ·
Thanks - what kind do you have?
exactly.
Go ride your quad Schooley....:nana:
1 - 20 of 30 Posts
