Hello all,
I was looking for some advice on possible issues on my bike. I have been hearing somewhat of a ticking noise coming from my engine. At first I checked the cam chain tensioner and adjusted it, however the noise did not go away. I then checked my valves, I believe 2-3 were out of spec technically, but they were not off by much. I don't believe the valves being off that little would create this noise but I am not a mechanic. I will upload a video of the bike running. Once the bike a running at idle speed it is not really noticable. However, once the bike revs past 3500 rpms then the noise is definitely there. Once the bike is colder that noise is also louder then when the engine is warmer 180+ degrees.
I recently took the bike to the kawi dealership to diagnose the problem. Spark plugs were replaced and a compression test was done which turned out good. He believes the issue is the cam chain itself. To replace the cam chain it would be 2000 for parts and labor. Sounded a bit odd for this to happen with less than 10,000 miles. I did purchase a APE manual cam chain tensioner however that did not fix the issue.
If anyone has any suggestions or has dealt with a similar issue, it would be much appreciated
https://www.youtube.com/watch?v=kUWauBPDgfo
