Huh that's funny...
I found another video while I was watching yours:
http://www.youtube.com/watch?v=Rye6RQHdCeY
Um doesn't choke mean they close to limit the air, hence the word chokeHmm u might be right. They also act like a choke and open up when the bike is cold just to get the engine up to operating temp. My bike was cold when I tested it out so thats what might be happening actually. Im not gonna have a chance to test it for the next 2 days tho. Ill report back when I test it out!
...yes...Um doesn't choke mean they close to limit the air, hence the word choke
Ahhh so thats how it works eh? I assumed it opens up and thats what causes the higher RPMs at startup.yea no choke Im afraid
ecu just runs the injectors longer to run the engine rich during warm up (causes the 'fast idle' the bike usually starts with, before it settles down to normal idle speed)
Um....i'm pretty sure you do not want to do this.....I believe that could mess with the calibration of your TPS (Throttlebody Position Sensors)...someone correct me if im wrong? :Omine do exactly the same thing
you can turn them by hand, so they're fully closed (I do this when airbox is off, to keep shit from falling in), and they turn back as per your video, so the vane is vertical on turning the ignition
so think you're ok..!
