1 - 4 of 4 Posts
this screw is totally stripped...and its in there extremely tight..i tried using an extracting set but i think a little piece of the extracting bit brok and all of my drill bits keep breaking.. ive tried everything please help!?
I would say get a big enough drill bit and drill til the head comes off then pull the fairing off and use vice grips on the little bit that will still be sticking out.
alright ill try thanks
did yoy spray the bolt with wd-40 or crc before you tried to undo it?
1 - 4 of 4 Posts
