1 - 10 of 10 Posts
I have a 07 zx6r with 10k miles on in I bought it today and I rode it for a while with no problems, but later when I came back to ride I'll start it but when I shift to 1st to take off it stalks out would it be the clutch cable or something worse.
flip your kickstand up. if it is down, and you put it into gear it will stall. it does this so you dont ride away with the stand down, turn left, and have the stand pivot the rear of the bike off the ground causing you to crash. Ski
That was it exactly thank you so much this is my first Kawasaki so I wasn't sure but that is a great safety feature
Super Moderator
Or clutch sensor or kickstand sensor but I'm inclined to go with above.
Ey3
Super Moderator
How long have you been riding?
Welcome btw
Ey3
uhhhhhhhhhhhh
Reactions: Mystery636
another great feature is the positive neutral finder. when in first gear, and sitting still the bike cannot be shifted up (or down if you have gp shift) into any other gear but neutral. it cannot go into second. makes it easy to find neutral, especially for newbies.
so make sure you are downshifted to first BEFORE you stop moving, once stopped and in first , one klick up and your green neutral light will come on, and you are free to release the clutch while the bike is idling (waiting at a light for example). light turns green, click down one, and off you go. saves wear on the clutch pack too.
ski
You might need to roll it forward an inch if sitting in neutral its pretty common used to freak me out till I read how normal it is
I was not aware of a positive neutral finder. I can usually half kick down from second so really isn't required. I consider myself new on these bikes. Is it just me or is shifting from 2nd to first a bit too clunkish to be necessary in regular riding situations.
ski
IMO its never a good idea to be in neutral at a redlight. always better to be in gear and ready to move if you have to.
positive neutral finder is a great feature...not really needed, but fun to have.
1 - 10 of 10 Posts
