ok. low-sided on 1/17. Minor plastics damage. Removed all the plastics and otherwise stripped her down to the throttle body on 2/25. I had started her up once or twice in between those dates, just because I was nervous there was something wrong I wasn't seeing and just wanted to hear her run to comfort my worries. All was well.
Put on block off plates and jumped the remaining connector with a small resistor per instructions on another post here on 2/26.
Got most of the plastics in a couple days ago and started putting her back together. No drama. Toss the battery back on there, turn the ignition on and the battery seems real strong. I pop her in neutral and try to give her a start. I can hear the servo do its thing. I hear what I am pretty sure is the sub-throttle, but I hear nothing from the starter. I don't get any codes, but if I hold the starter button down for about 6 seconds or so, ktrc and engine light come on, and my power and ktrc setting indicators all come on and start flashing on my display.
I get no codes. I tried jumping the battery from my truck with no luck, although I didn't let it sit long, and the way the bike comes on when I turn the key, it seems real strong. I took the bike back down to the throttle body to make sure I wasn't missing some connector, but all seems good. I can't figure out what I'm missing....
