That's awesome you did this and saved yourself money. I just did the same 10K service on my bike. I didn't change plugs at the 7.5K, and like you, there wasn't much build up at all. It's ridiculous how much "labor" costs.
Throwing in an aftermarket air filter like K&N or BMC is not really much of a "track upgrade" but more of a preferred maintenance item as far as Im concerned. Its nice being able to clean and reuse the same filter over and over rather than having to buy a new OEM one each time. Just my two cents.The air filter was dirty, but not too bad. I replaced it with the same Kawasaki OEM air filter. This filter is just fine for my riding needs. I don't go to the track, so no need for a upgraded air filter.
How many times do you really need to buy a new air filter. I stated in my original post that the filter wasn't that dirty after 10,000 miles. I have no problem spending $40.00 for a "NEW" air filter every 15,000 miles. You also need to buy the cleaning solution for the K&N on top of the cost of the filter. MMMMMMMMMMM no thanks.Throwing in an aftermarket air filter like K&N or BMC is not really much of a "track upgrade" but more of a preferred maintenance item as far as Im concerned. Its nice being able to clean and reuse the same filter over and over rather than having to buy a new OEM one each time. Just my two cents.
Why cant the OEM filter be cleaned and reused?Throwing in an aftermarket air filter like K&N or BMC is not really much of a "track upgrade" but more of a preferred maintenance item as far as Im concerned. Its nice being able to clean and reuse the same filter over and over rather than having to buy a new OEM one each time. Just my two cents.
The manual states every 11,400 miles for OEM air filter. Like I said, it wasn't even that dirty at 10,000 miles. :nana:I believe because the manual also states to change your OEM filter every 600 miles or so did you check that part of your preferred maintenance? Any filter that gets recommended to get changed out that quick I'll pass and buy one that's reusable the oil isn't that costly either I've bought one bottle 5 years ago not even made a dent in it with 3 different vehicles all of them get cleaned every year
The cleaning solution cost $9 lol.. Ive used it 2x and you can barely tell its been used, itll last a while. I dont wait for "xxxx" miles specifically to check my filter anyway. If i have my tank up and its been a few months/couple thousand miles, ill take a peek and give it a clean so the K&N suits me well.How many times do you really need to buy a new air filter. I stated in my original post that the filter wasn't that dirty after 10,000 miles. I have no problem spending $40.00 for a "NEW" air filter every 15,000 miles. You also need to buy the cleaning solution for the K&N on top of the cost of the filter. MMMMMMMMMMM no thanks.
