1 - 13 of 13 Posts
This shifting issue is pissing me off. I can't understand it. The shop said it was fine. But two distinct clicks, pops going into second gear shouldn't be fine. Should this have travel out and in?
[/IMG] also should the shift rod have and freeplay? Spinning side two side?
Discussion Starter · #7 ·
I'm not talking about that star looking part I mean the whole assembly
You mean the shift lever is jumping a tooth on the shaft when you shift? Just tighten the pinch bolt a little. The bearings on the linkage rod may need some lube too, I've heard of those getting sticky and binding.
Discussion Starter · #11 ·
I guess that could be what I'm feeling. I feel like if it was internal tranny it would make a grind? Is that true? Or at least effect the ride
It comes from vibration if you ride hard in Low gears
1 - 13 of 13 Posts
