Hi! My name is Patrick and I'm new to this forum. I own a blue '04 zx6r and it works great; put it about 5500 mi on this thing. I don't ride it too hard and never shift without using the clutch. Of course, I have a problem and so I was hoping you guys could help me figure out what step(s) I should take.
On Tuesday, when I was going to work, I shift up through all gears fine. I could even downshift all the way through 2nd, but then the shifter would lock in the 'down' position and I couldn't shift into first at prolonged stops and on-ramps. When I inspected the shifter it moved right but it was not 'snapping' back into the center position. I used the car the next few days.
I didn't think much of it until today, when I took off in a hurry, cuz I was running late for work. NOW the darn shifter feels like it's jammed, or too tight. I have to really step on it or pull on it hard (I even had to use my hand...) for it to shift.
I figure my shift forks are bad, and I read some of the posts here so I'm probably looking at a major expense here.
Any ideas? Please advise.
welcome mate, sorry i cant help ya but hope someone on her can
If the lever isn't springing back to its normal centred resting positon it might be something as simple as needing lube at the footrest pivot, or one of the rose joints, or a broken spring on the ratchet and pawl set-up. (Not sure if it's internal to the gear box or external on those things, some are som aren't).
I'd be checking that the lever / linkages are free to move first.
So I took it to my local reputable shop and they took a look. Both mechanics that looked agreed with Steve_TLS in that the joint needs lube. During troubleshooting, the shop owner/mech sprayed on some lube and forced it in with an airhose, then worked it in. The lever worked wonderfully afterwards. Now I gotta take it apart and give it some much needed TLC.
COST: Nothing.
Thank you all!
welcome and get it lubed and u should be fine, the 03-04 636's didnt have a known transmission problem like the 05-06 636's did
