1 - 5 of 5 Posts
Hello all new to this !!
Gone to start my p7f 600 after winter all fine apart from no Rev needle and no digital stuff on screen ??? Gear , mph , temp etc
The back light is on , neutral , main indicator light all work
Basically half the dash isn't , messed with connectors , checked fuses , taken dash apart but no joy
Please help cheers meako
"Dead" battery. You might have just enough juice to get some of the shit to light up, but not enough to start or engage some of the motors.
Either throw it on a battery tender or you might just want to consider getting a new battery. Batteries worst enemies are sitting because of Sulfation:
Lead–acid batteries lose the ability to accept a charge when discharged for too long due to sulfation, the crystallization of lead sulfate.[20] They generate electricity through a double sulfate chemical reaction. Lead and lead dioxide, the active materials on the battery's plates, react with sulfuric acid in the electrolyte to form lead sulfate. The lead sulfate first forms in a finely divided, amorphous state, and easily reverts to lead, lead dioxide and sulfuric acid when the battery recharges. As batteries cycle through numerous discharges and charges, some lead sulfate is not recombined into electrolyte and slowly converts to a stable crystalline form that no longer dissolves on recharging. Thus, not all the lead is returned to the battery plates, and the amount of usable active material necessary for electricity generation declines over time.
Sulfation occurs in lead–acid batteries when they are subjected to insufficient charging during normal operation. It impedes recharging; sulfate deposits ultimately expand, cracking the plates and destroying the battery. Eventually so much of the battery plate area is unable to supply current that the battery capacity is greatly reduced. In addition, the sulfate portion (of the lead sulfate) is not returned to the electrolyte as sulfuric acid. It is believed that large crystals physically block the electrolyte from entering the pores of the plates. Sulfation can be avoided if the battery is fully recharged immediately after a discharge cycle.[21] A white coating on the plates may be visible (in batteries with clear cases, or after dismantling the battery). Batteries that are sulfated show a high internal resistance and can deliver only a small fraction of normal discharge current. Sulfation also affects the charging cycle, resulting in longer charging times, less efficient and incomplete charging, and higher battery temperatures.
Cheers mate , battery is fine. Starts bike without hesitation and everything else works ??!!
Hello and welcome!
The problem could still be your battery or charging system. Download your service manual from that section of the forum, and follow the test procedures for your charging system.
oh ok, didn't realize the bike was turning over. With all electric problems you should always start with the battery anyway. They do some WEIRD shit.
1 - 5 of 5 Posts
