1 - 3 of 3 Posts
Hi I was chasing a bit of advice about replacing steering stem from a 1994 zx9b to a 1996 zx6f as the 9 has a lager dia stem and I was wondering if they make bearings kits to fix this or if I have to press out the 6 stem and make sleeves to make it fit the larger triple of the 9.
If anyone has done similar or the same any help would be great.
there is some thread on here on changing forks ,i had a zx6r 2001 and i fitted zx7r usd forks ,i didnt like the way it handled,the forks i founds heavy , not to great ,i have now converted to 06 usd forks have you thought of going down that route as doing all that work ,you could do all that work and something a bit more modern but if its down to cash then your idea is better for the pocket
1 - 3 of 3 Posts
