My borther had a pucker moment after his front tire valve stem let go. Tires replaced 2 years ago, he couldn't remember if valve stems were replaced. The shop he went to seems pretty decent and had no issues finding my rim repair when i replaced my tires and think their standard practice is to replace valve stems...
As far as I know, my '09 still has the original stems. I meant to change them out this time, but didn't plan ahead. They don't appear to be degraded. So far. When I see cracking, they're done.
I would go to the angled metal stems, were I to change them. Somewhat contrary to my understanding of the physics:
I'm not going to add weight to the top of a rubber stem, as that will cause greater fatigue, compared to the very light weight plastic cap. Lots of outward force when the wheel is spinning, with many random jolts from the road. A lot of those shocks will not be perfectly aligned with the plane of rotation, which will cause the stem to flex. The more mass there is at the tip, the greater the force applied. The longer the stem, the greater the leverage which means more flex.
The vertical, thick sided tapered shape of the rubber OEM stems resist flexing quite well. So long as you don't overload the system.
The angled stems exacerbate this loading, in a huge way. Guaranteed to flex much more because they are longer, and bent out of plane with the principal loads applied. This is why they're metal, vs rubber. Metal does a much better job of resisting flex, which I expect can easily compensate for the load. Strength goes up at the square of volume. Twice as thick, four times as strong.
The real limiting factor would be the mass. Mass goes up, at the cube of volume. Twice as thick, eight times as massive.... Not a critical element, for a valve stem......
I do my own tire changes and I change stems every tire change. They only cost a couple $$ and it seems like a false economy to not change them every time as a basic maintenance item. Like OP, I have had a stem fail and leave me with a flat tire, but thankfully mine wasn't while riding.
The problem is you may not see cracking. The one I had fail looked perfectly OK until I tried to twist the cap off to put air in and the whole stem came off in my hand.
yeah...that huge "grenade" valve cap is the culprit 100%
I've never ever seen this happen to any of my cars or bikes ever and other than my bike, i never change valve stems. They just don't fail, like ever.
On the bike i have 90 degree valve stems, because it's easier to check pressure and add/remove air to the front because of that huge brake disks.
As someone doing hundreds of tire changes each year....
I replace the rubber stems on any bike more than 5 years old- isn't a choice for customers it is just done-, since I have no way of knowing when or if they were ever done........ but-- the bikes with aftermarket metal 90* or whatever......... those I leave alone even though I have had way more of those come in leaking air than the rubber stems
just something about replacing the rubber stem for an aditional $1 (most) the customers appreciate, but replacing the seal on a metal stem for $5.00 they bitch about
and any of the bikes I know are heading to the track, if they still have rubber stems I do put in metal stems ..... or strongly advise they do--soemtimes thye just go new rubber when they are too cheap for their own good..........
All that said.......... I left in my original rubber stems for 8 years before going to metal ones and had no issues. I still know people who are on 15 year old + oe original rubber stems because they only wear out their tires about once every 7-10 years
alot of their life expectancy depends on sun exposure and the such.....
maybe even more so- if you use harsch chemicals to clean your wheels often
