1 - 20 of 77 Posts
I just purchased a 636 that has been kept in a shed since 2009. I look forward to starting a build thread and sharing the process with everybody here. Also look forward to any knowledge from other forum members throughout the process!
This will be my 2nd Kawasaki and my 2nd attempt at bringing back some life to an abandoned motorcycle. My first attempt was very successful and only took 2 weeks from start to finish when I found a neglected 2001 CBR F4i.
I already received the title and am waiting to pick up the 636 next week! Cheers to all!
'05 are known for issues with the ECU..... The under seat exhausts tend to cook them in some cases.
Other than that, seems like a stellar bike.
Thank you, RJ. This is the type of insight that I’m looking for. The bike does have an undertail Muzzy exhaust...was the stock exhaust the culprit or any undertail exhaust?
No direct experience, so it's all anecdotal.... if I had to guess, I'd think any aftermarket can would not be as insulated as the OEM can. Hence, more heat under the seat. Airflow is a crucial part of the cooling process -- if someone adds an aftermarket module under the seat area, and that blocks airflow (which is already substandard IMHO) and adds some amount of heat as well -- when you cap that off with the heat from the catalytic converter burning off the excess fuel, into a less insulated muffler system I can see how it may end up hot enough to start breaking down the ECU. The cat would burn off more, if a fuel enricher is in use, as more would make it out of the cylinder and onto the cat.
The typcial solution is to replace the '05 ECU with one from an '06. As I have no idea if there is any physical difference between the model year ECUs, I have to wonder how successful this approach is. You don't hear anywhere near as much about '06 having this issue, so there's some real possibility of a change.
Were I to buy an '05 in need of TLC, I'd probably start with gutting the catalytic converter. That's going to reduce the exhaust temp by quite a lot of degrees. It will stink more, and may appear more sooty at the tip of the muffler; if it's cooler exhaust that can only be good for the ECU. Next, I'd add some heat insulating tape on the side of the tray facing the pipe, to reflect away as much of the heat coming up off the pipe as possible. Make that patch wide enough to let the heat find another path up, that does not include penetrating the tail section.
If the '05 OEM ECU acts up after all of that, I'd get a used '06 ECU, if one can be found.
I’ll keep all of that in mind. Hopefully this bike will just need a fuel system cleaning new tires and chain and a battery. All fluids of course
Welcome to the forum.
Don't forget about the suspension fluids.
No issues with my 06 and under tail exhaust.
Thanks! I may try to flip the 636...depends on how much I spend to get it up and running properly. If I keep it I will take it to a local suspension guy that used to race professionally
A few photos of the bike. It has been stored in this shed since 2009. Looks bad but I’m excited. Has an oval Muzzy exhaust. I haven’t picked it up yet. Waiting for the keys.
I'd expect suspension problems due to failed seals. Electrical connections will be suspect, and there is a significant chance of vermin having my moved in. Open the air box, check for rodent nests.
Tires, battery, brake lines, driveline. Valve clearance check....... Then, cosmetics.
Personally....
Full tear down to the frame. Maybe even drop the engine just to clean everything up. :p
It's dirty enough that it could use it.
Agreed with RJ
- That shed definitely has rodents in it. Airbox almost certaily has some shit (no pun) in it). Check for chewed up wires too.
- Suspension seals as mentioned.
- Toss the battery and get a brand new one.
- change ALL the fluids obviously (brake fluids too)
- Gonna need to fresh rubber too.
Assuming it's in working order it shouldn't be much to get refreshed. Nice find!
Discussion Starter #11
Thank you for the replies! I tried joining a few facebook 636 forums but the mods haven’t accepted me yet. Mainly trying to find part outs to pick up spare parts...going the budget route and need all the help I can get
I wouldn't bother with most groups on FB unless you're just looking for trolls.
Join this group for parts. https://www.facebook.com/groups/450439275077412/
My bike sat in the previous owners garage for 5 years. Clutch plates actually stuck together. I pulled more dry dog food out of the nooks and crannies of the bike than I care to remember due to mice....
good luck and keep us posted!!
Ducman
Discussion Starter #15
Ducman
Did you reuse the clutch plates?
I was able to source a rightside rearset with brake reservoir and master cylinder. Still looking for a fuel pump and if I can’t find fuel injectors, I will just get mine ultrasonically cleaned.
Probably didn't.
If you can push the bike with the clutch pulled in and in gear, then your plates probably aren't fused together. :bigthumb:
Discussion Starter #17
Still waiting for the key...previous owner says he cant find it. Did find a complete fuel pump and injectors!
I put in new plates. You might be able to use them again but you should make sure the metal slipper plates are clean and not 'varnished' like mine were.
Locksmith can make you a key as long as you're the registered owner or have bill of sale.
Discussion Starter #20
It’s looking like I will need to get a locksmith to make me a key. In other news, a used oem fuel pump and throttle bodies arrived in the mail. Going to pick up a battery...going with the Everstart walmart for cheap and will need a chain. Any idea what is a good chain for the money? I think it’s 108 links, stock
1 - 20 of 77 Posts
