Hey guys and gals I am doing a whole bunch of stuff to my 2013 636. List is at the bottom of this post. I bought it used and I want to give it a thorough advanced tune up/maintenance before next year. Along with all the fluid flushes I was going to do the following:
Clean fuel pump
Clean fuel injectors
Check clutch basket
Clean Brake Calipers
Clean air filter
Valve adjustment/throttle body sync
Steering stem and bearings
Rear suspension linkage and bearings
Clean chasis
Clean swing arm linkage and bearings
Clean wheel bearings
Replace spark plugs
Front fork and shock rebuild with racetech springs
Is there anything else I can or should do? Or tips you guys can offer up on what I plan on doing already? Mainly looking for things I can do while the tank and airbox are off. The bike has about 28 000km. I have attached a couple of photos so you guys can see what I have access to. I plan on syncing the throttle bodies once I have completed all the mods thats why its not part of the list.
New stuff going on the bike are as follows:
Left side OEM clip on old one is stripped out where the bar end goes
Replacing stator cover old one is scratched
New OEM 2018 fairings (got a wicked deal and my 2013's are scratched)
New EBC pads and rotors
Vortex chain
Vortex front and rear sprockets
Captive spacers from captivespacers.com
Lightech chain adjusters
Core moto steel braided brake lines
Driven Halo front and rear brake reservoirs
Vortex 3.0 shorty levers
Driven D3 grips
G2 street competition quick turn throttle
Full graves titanium exhaust headers with two bros slip on (2 bros came with bike)
2012 velocity stacks
Driven block off plates
Antigravity Lithium Ion battery
Flash tune bike side harness
Bazazz zfi tc qs
Bazazz zafm
Vortex rearsets with banjo switch
Ohlins SD 042 steering damper
Tech spec tank grips
GB racing covers
R and G axle sliders
Impaktech race rails
R and G flasher relay
Competition Werkes LED Intergrated tail light
LED headlight, running lights and turn signals
Tinting the headlights, brake light and turn signals with vvivvid dark smoke headlight tint.
I think thats it. Again any tips or suggestions on things I can clean, rebuild or do maintenance on as I go would be awesome. I will post more pictures as I go as well
Clean fuel pump
Check clutch basket
Clean air filter
Clean chasis
Replace spark plugs
Vortex chain
Driven D3 grips
Bazazz zfi tc qs
Bazazz zafm
GB racing covers
