1 - 2 of 2 Posts
so I hAd my rear tire changed and they took off the sprocket and the bearing inside the sprocket or the mettle spacer fell out that goes between the wheel barring and the sprocket and I put it on and drove on it for one day then my wheel started clicking. I looked and saw that my axle (inside the wheel tube) was super loose. Do I need knew wheel? And is it still safe to drive?
Just check all the metal on metal parts, make sure nothings blinded up real bad. Probably want to also check the actual wheel bearings, make sure they aren't shot. As long as that's all good and you get the spacers back in or the axle tightened, rear tire should be fine.
1 - 2 of 2 Posts
