I have a 2003 zx6r and am at the end of my engine rebuild and am still troubleshooting why it wont start. The question I have for you all is how exactly does the crankshaft sensor work with the crankshaft gear, because my timing is all right but i think my actual gear is off a little when it is all Top Dead Center.
*would the gear on the end off the crankshaft make my engine not start if it is off a couple notches when at TDC? and how dose the sensor work with the gear?
Im just curious and would like to know how they all work together
The marks need to be lined up properly whether the sensor requires it or not, but I'm pretty sure the sensor requires it to be in the proper position to function correctly as well. Why not install the gear correctly?
I was looking at the gear on the crankshaft yesterday and I am pretty sure now that there is only one way that it can go on. So now i just need to figure out why it still isnt starting.
There has to be a way to adjust the timing gear, or 1 and 4 aren't at TDC.
Your crank position sensor is what is called a Hall effect sensor. As the timing gear teeth pass by it, the sensor measures each as a magnetic pulse. Based on pulse frequency, the sensor can measure crank speed. There should be an 'interruption' somewhere on the gear where there are double teeth (or two in a row missing). This gap when passing by the sensor would help signal where the 1 & 4 cylinder are.
Concerning your original question, it might be worth testing this sensor if it's indeed bad. Do you get any error codes trying to start the bike?
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Kawasaki Ninja ZX-6R Forum
