Questions about my 2013 ZX6R...
962 Views 8 Replies 5 Participants Last post by  wiplash
6
Just bought a ZX6R and have few questions.
It's been lowered for sure in the rear.
What link and stand does it have?
The tail light is not sitting flush against the body. It's missing some sort of clip or bracket that goes where I highlighted in the picture. Does anybody know the part number for it or have one laying around?
1 - 9 of 9 Posts
The link is adjustable you can probably go back to factory height same with the kickstand and the tail light you can check bikebandit.com or cheapcycleparts.com for the parts microfische and it gives a break down of all the parts in the different areas.
Looks like a protek kickstand and possibly the same for the link
I think I'll just zip tie the tail lights for now. Nobody will ever know it's been zip tied.
2
Are you sure it's not just installed incorrectly? There is a hook/tab in the tail/brake light cover piece that should slide into the part you circled on your taillight:
If the hook/tab is broken/missing, then you can get a new cover (the part number is 14092-0989): 2013 Kawasaki NINJA ZX-6R (ZX636EDF) Side Covers | CyclePartsNation
Thanks, I'll check that out.
What Strider said.There is a hook on the trim piece that the rubber piece in the taillight slips into. It takes some wiggling to get it to install correctly. You need to get the left and right side section of the tail in correctly along with that tab. You have to align three different things at a time, left, right and center. You aren't missing anything, just not installed correctly.
The tab on that trim piece is broken. I've ordered a new piece.
Thanks for the help fellas.
1 - 9 of 9 Posts
