I just got a set of yoshi frame sliders for my '15 frame sliders, should i use loctie when mounting them?
Super Moderator
What do the instructions say?
Ey3
Don't use the red stuff... you can use the blue. Just in case you ever want to take them off, it's easier to break it loose.
Dont. The day you crash and the slider gets bent, its a LOT of work getting it off. That will not be easier with loctite. OEM bolts does not use loctite, so i see no reason why you should need it.
I go around the bike and make sure every bolt i see is still nice and tight as routine maintenance. Why not just do that?
