1 - 3 of 3 Posts
Okay I'm looking for fresh suggestions on how to fix my 03 ZX6R's idle/stalling issue. The idle still fluctuates and then eventually my bike will stall.
Here's a link to an old thread explaining the issue in more detail. There is also a video you can watch if you haven't seen it before: http://zx6r.com/mechanical-technical/21191-2003-zx6r-idle-issue-dies-video-update.html
This is a list of everything I have attempted and has not worked.
-Valve Clearance Adjustment
-Throttle body sync
-Ran at least 4 bottles of cleaners through the bike. (Sea Foam, Lucas, etc.)
-New spark plugs
-Cleaned the throttle body assembly
-Checked the timing
-Cleaned K&N air filter
-Checked for air leaks (couldn't locate one but it's still possible that there is one)
-Oil change
That's all I can remember right now. None of these have worked.
So I only have 2 other ideas that someone suggested, the throttle position sensor and the inlet air pressure sensor.
Does anyone else have any knowledge on what it could be?:O It would be much appreciated!?
definitely keeping my eye on this thread. any misfiring? what about when you ride it how does it act then? if you can ride it?
Nope, no misfiring. It runs great while i'm riding it. As long as i'm giving it gas it wont stall. I ride it everyday. Bought the bike with 11k miles on it and now it's at 17.5k miles. It's had this problem since the day I bought it ahaha.
1 - 3 of 3 Posts
