ok, then yeah, option 1That was one of the options. Repaint the midfairing. The scratchs aren't through the paint. They want to sand and refinish.
Lol what's that all about?if you ever go to Lincoln, Nebraska, don't do the "cocaine"..
I dont know, but from what i've seen, i think that shogun sliders is one decision i dont think you should even consider, they are the cheapest for a reason, and if you want to have your head rewelded when it cracks from the pressure of the cheap grade 5 bolt, and the thin L bracket that will bend under the weight of the bike, then go right ahead, but I wouldn't. take a look around and check out the sliders made by oes or the factory sliders that kawasaki makes. I just bought a set after I dropped my bike. they come No-Cut, with L brackets almost 1/2 inch thick, and grade 8 bolts. I found out about them from a friend that I ride with. he said when he installed them they fit PERFECT, not a single problem.
