So today I did a rad flush and front and rear brake fluid change for some reason when I put bike into gear the FL light comes on never seen this light before. Please help! ?
Definitely going to need more info than this to be able to be any help at all
Not much more info I can give I went over everything checked everything all wires and plugs tight. Won't come on un till you put in gear
It's probably worth pulling the code to see what it's complaining about. That's what it's there for. Maybe the kickstand switch isn't working, which would kill the engine when you put it in gear, although I don't know if that would throw a code. Definitely worth having a look though.
http://zx6r.com/guides/12417-how-pull-fi-codes.html
Motor does not die can still ride but when put in gear the light comes on I will run the test when I get home thank you very much
