ARC was also the first place I heard a definition of carving a line through a corner.
When the suspension is right, when the power is right, when you don’t have to adjust your line, change acceleration & the simply flow through the corner….. you have carved that turn. When you set up your line so you flow from one to the next with no wasted motions….. you may carve a number in succession. This is when you see folk that can drag fingers on pavement, skim their knee pucks along their chosen path. There’s basically no steering input or anything else. Just the flow.
That can be really slow, really fast, or anywhere in between.
You can easily see when someone is hacking a corner up making multiple changes in any number of things relating to executing the corner. Their chosen line becomes a series of choppy lines as every ‘correction’ is applied. Smooth looks slow, smooth is fast.
