1 - 7 of 7 Posts
Hey guys,
Something put a hole through my oil pan (third pic) so I'm just installing the new one, however I'm not quite sure if the oil screen is supposed to be screwed on with a bolt where that black hole is (first picture) or just sit (as in 2nd pic). I don't see a bolt and if I try to just put it on it doesn't feel secure enough. I checked the diagrams and can't seem to really see a bolt so just want to confirm if anyone has had experience with the install and knows. Also, I was able to remove it without taking the exhaust off but would I have to take it off to put it back on? Thanks!
No bolt- it is friction fit of that seal and then the pan itself holds it up there.......... those bosses with the machined top inside the pan.......
1 - 7 of 7 Posts
