1 - 20 of 20 Posts
What oil type should i use for an 07 Zx6R? 10W-40? What API?
What kinda oil filter? Can i just get it from Auto Zone or something?
Any help would be great..
thanks :laugh
you can get the mobil 1 mx4t synthetic from auto zone or you can get the shell rotella 5w40 synthetic from walmart, im currently runnin the rotella and love the stuff
id go with mobil 1 10w40 thats wat i run and love it and i jus get my filter from walmart
Discussion Starter · #4 ·
The shell rotella 5w40.. isnt that for trucks and other heavy engines? Have u been using it for a while? Just wanna make sure its safe..
Also, ZX636, do u use Mobile 1 10w40 high mileage? Have u noticed any clutch issues by using an automobile oil?
don't us any automotive engine oil, they have detergents in the oil that will ruin your wet clutch, use motorcycle specific oil. i use repsol 5w40 with a K&N filter and my baby has about 7500miles on the ticker. I have had no problems running this combo.
you can use the Rotella synthetic or standard oil. i use Mobil 1 racing 4T and a Bosch 3300 oil filter. you can use automotive oil as long as its not Energy Conserving (this will ruin your clutch). personally, i just use the Mobil 1 bike oil because...i like Mobil 1 and it works!
i use motul oil and K&N oil filter
yes ive been runnin rotella for a while now & havent had any problems even with the clutch, its rated toward big trucks but if you look on there site its safe to run in a wet clutch setup bike & if you look at the price vs other motorcycle synthetic oils you will come back :)
no i never noticed nething different seems fine to me and it acctually goes into 1st from neutral alot smoother than wat i was running before
Discussion Starter · #13 ·
I ran the rotella and it works good so far.. Got the filter from walmart... Spent about 5 hrs trying to get the darn filter out.. thank God its done. Thanks for all da help bros.
that rotella is some good stuff man, also i hope you poured alittle oil inside the filter before installing
Discussion Starter · #15 ·
I didnt pour oil inside, but i did rub some oil around the edges with my finger. My bike starts fine but when i put it into first gear, it shuts off! Do i need to take the filter out and pour oil in it and re-install? I dont know what else could be the problem.
i would check your kickstand sensor... if its unplugged or shot it will run while in N but shut off as soon as you put it in gear. not putting oil in the filter before install should not cause this problem.
When you put on your new filter don't tighten it with a death grip so you can service it much easier next time :)
When I got mine, the guy that had it before me used thread lock on the oil filter and it was a nightmare to remove without letting any of the threadlock fall into the engine.
1 - 20 of 20 Posts
