1 - 11 of 11 Posts
So I just bought a set of used 2008 rotors to throw on my 2006. I know that both rotors are 310mm in diameter, so I figured it was a straight swap.
One thing I just realized, though, was that the hat of my 2006 rotors denotes 5mm while the hat of the newer rotors denotes 5.5mm.
I am assuming this isn't a major issue, but is there any shimming I need to be concerned with? When I pull off the 06 rotors, should I reuse the factory shim that is in between the rotors and wheel?
-05-10 ZX6R Wheels are all the same
-98-04 ZX6R Rear Wheels the same
-05-10 ZX6R Front Rotors are all the same
-98-10 ZX6R Rear Rotors are all the same size and bolt pattern, they just went to a "Wave" rotor in 2005
-98-10 ZX6R Front Sprockets are the same CHECK PITCH 2003 went to 520!
-98-10 ZX6R Sprockets all have the same bolt pattern, 2003 they went to 520 from 525
-98-04 ZX6R Mirrors are the same stud spacing
-05-10 ZX6R Mirrors have the same stud spacing
-05-08 ZX6R Swingarms are the same, in 07 they changed the look slightly, but still the same bolt spacing and sizing.
-03-08 ZX6R Clip-ons are all 50MM and work with each other.
-03-06 ZX6R Top Triple Clamps are the same just look different
-03-08 ZX6R Forks the same dimensions are the same, just 03/04 had smaller rotors so the caliper mounts were 10MM shorter.
-03-10 ZX6R Calipers all bolt up, 03-06 ZX6R Exactly the same 07-10 ZX6R went to Nissins which are a much better caliper.
-98-10 ZX6R Bar Ends all the same
-00-10 ZX6R Gas Caps interchangeable
-06-10 ZX10R Front Wheel same as 05+ ZX6R
-04-10 ZX10R Rotors the same as 05+ ZX6R
-98-03 ZX9R Rear Rotor same as the ZX10R/ZX6R
-98-04 ZX6R Passenger Pegs the same
-05-10 ZX6R Passenger pegs the same
-98-10 ZX6R and ZX10R Rear Calipers are all the same
-98-10 ZX6R Cush Drives are the same piece
-98/99 ZX9R Front Rotors are he same as he "G" and "J" and ZZR600
Ebster use the search there is a complete comparability list someone posted. Just don't know where its at lol
Also either shave the rotors or swap the caliper. And yes you can use the same shim
Discussion Starter #10
I have two different styles on my bike (5mm and 5.5mm). No issues.
Thanks dude, figured it would be fine, just wanted some reassurance. I had read many threads about rotor, wheel, caliper, etc. compatibility but only after buying these later model rotors became aware of the small thickness difference.
Ill swap them in direct and be off to the races...literally :)
1 - 11 of 11 Posts
