1 - 4 of 4 Posts
I have a 2000 zx6r I need a carburetor diaphragm slide and found one but its off a 1999 zx6r the part numbers match but I'm still unsure if I should buy it. any suggestions?
Have you seen it and know it is good?
I guess if it is cheap enough you have little to lose, but I refer to be installing new parts on my bikes.
Is it just the rubber diaphragm you need?- those only retail like $40
or is the slide itself bad?- those are well over $100
If it is just the rubber diaphragm, I would for sure buy new
Reactions: Naussy
Discussion Starter · #4 ·
ok thanks guys I did well got the slide and spring used though but mint for $ 40.00. I'm sure glad the years of bikes still use same parts it gives us more choices.
1 - 4 of 4 Posts
