I recently purchased my 2003 ZX636 and had a few questions regarding the suspension.
I've been riding it for about two weeks now and never really noticed any suspension issues, but today I decided to ride it much harder than before and noticed my rear tire seemed to get a bit soft when cornering. First off, I'm a big guy, 6ft tall and 245-250lbs. Questions:
Should I be riding with pressures a little bit higher than recommended due to my weight?
Also, what do I need to do in regards to having my suspension set up to my weight? This bike is still set up completely stock, and I know for a fact your typical setup isn't for someone my size.
I'm pretty confident with my riding posture/position being correct, using everything I learned in the MSF course, so I'm wondering if this has to do with the tire pressure and suspension. It definitely took a little bit out of my confidence when entering corners, and that makes twisties not nearly as fun
lain:
Also, The front tire was new at purchase, rear tire has about 85% tread.
