If you go to Colorrite.com and use the pull down menus to select your year, make, and model. Should get you to the OEM color code.
The issue will be with the paint on your bike having weathered, and faded to some degree. The OEM will not be a perfect match as a result, unless the bike has lived inside a garage for it's entire life.
