1 - 7 of 7 Posts
Ok these damn frame sliders are making me sick i put left side on that was no problem but the right side i stripped so i had my girl pick me up the bolt out remover i got the bolt out but as i was doing it i saw the castle nut and threaded bolt turn a little bit any idea how im supposed to tighten that back up dont want to be ridin with a loose engine mount bolt any help would be appreciated thanks
a flathead screwdriver and a hammer might do the trick.
If it were mine.. I would get the right tools.. and torque it to the correct specs.. if you use a screw driver it will beat it all to hell and look like crap.. and wont be the correct torque.. if your handy you can make some tools that will work too.. like this spanner wrench I made.. you can put a torque wrench on it too.. you can also grind down some old sockets too..
^^^Nice! I like that...
1 - 7 of 7 Posts
