hey guys im new to motorcycles and modifying bikes. I have a 1998 zx-6r and i want this thing to be sexy for the spring. It has big ugly blinkers on it right now which arnt attractive at all, plus one of them is broken so i had to take it up. And the back side is not very good as well, the fender is big and ugly and it has the same big gay blinkers on the fender w/ the license plate. i want to get rid of the fender w/ a fender removal kit, and i want to put a kawi green undertail on my bike so it makes it look better.
as for signals i was thinking these:
http://cgi.ebay.ca/Kawasaki-ZX6-ZX6...ryZ35598QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
or these
http://cgi.ebay.ca/Kawasaki-Ninja-6...ryZ35580QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
those are the ones i found if anyone knows of better looking ones for a 98 zx-6r i would appreciate if you could let me know.
as for the undertail:
http://cgi.ebay.ca/ZX6R-ZZR600-ZX-6...ryZ35580QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
fender eliminator:
http://cgi.ebay.ca/1998-2002-Kawasa...ryZ35584QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
i would greatly appreciate any input anyone has to say, like i said im new to mods and if someone has had experience with these it would be awesome to hear what you guys have to say and im thinking about putting a "xenon" light for the headlight and maybe changing the back break light, thanks guys!
i have the flushmounts in the second link. i'd go with whichever you like better.
you can do the fender eliminator thing, or integrate the signals into the brake lights. there are kits for that too. i'd get rid of the large ugly yellow rear blinkers either way.
Here is what I did...
Got a hack-saw blade and start cutting following the body lines.(take your time)
Cut yourself a good working templet.(take your time)
Cut up a bit of thin sheet metal. (take your time)
I painted the inside and undercoated the bottom.
Rivited and siliconed to water proof.
This is the intergrader I used.
$10-15 or so at Autozone.
TaDa!:)
It is some work but a lot easier then it looks and sounds.
PM me and Ill send you two schematics to wire up the tail light
with the intergrater for blinkers.
You will also need a heavy duty two prong flasher fron Autozone.
FYI...
Use your stock bulbs.
I have bought about every LED to make em bright...
stock are best.
You can do it Bro.
Just set you a day aside and take your time.
Good luck. Its worth it.
i just cut the rear fender in half and moved up the number plate closer to the tail light and left the indicators on the way the factory made em cos i dont mind them.. get clear lenses??
if you are not going to do what raized1199 says wich i think its the best..if not go w/blinkers 2the carbons..and rear undertail 1 ..goodluck
