1 - 5 of 5 Posts
I've done some research and cant seam to find a for sure answer im in need of the ram air covers for my 99 zx6r I know the 98-99s will work but cant seam to find any on the net for sale all of them are for the 00 and up my question is can I use and other years for the covers only besides 98-99?
Welcome to the forum.
They should be interchangeable. Most of the parts on the G and J model are interchangeable.
To make sure you should check out kawasakipartshouse.com or another site that sells OEM parts. They'll have the part numbers for each part that you can compare. Best of luck.
are you talking about the section from air box through the hole in the frame ,if so yep they are the same ,as the rest of it i wouldnt of thought so as headlamp area different ,and plastic mouldings
you can look them up on partzilla.com too
1 - 5 of 5 Posts
