Need help.. Fairing Bolts
4480 Views 16 Replies 13 Participants Last post by  commiehunter
I picked up an 05 636 with no fairings and i just got ahold of a mint set of blue oem fairings. Since i was able to find a nice set of oem's i want them bolted up properlly but buying all oem bolts would be really expensive Do any of you know of a quality universal or model specific bolt kit that actually gives you everything you need?
1 - 17 of 17 Posts
Just buy a bolt kit off of eBay and call it a day. Be sure it is a "full" bolt kit however. Those will have all of the plastic washers, well nuts, speed nuts and bolts you'll need. Should be around d $50 for the whole kit.
Dude, c'mon... He has to learn to do these things on his own, lol.
For $50 one can buy the oem bolts for all the fairings I think.
Be careful with painted bolts. Most of them, the paint strips off very easy.
This is true. I'd go with a set from here if you can't source an OEM set. The non-painted eBay kits will work too.
BIKEBOLTS, The motorcycle fastener source
The universal set of bolts won't look that great because they do not have all the necessary screws for that model. I have an '06 and I bought those kits on EBay once. I'm looking into getting titanium set of screws from probolt. They have the exact set you need. If you want something cheaper look into stainless steel instead of expensive titanium.
I had a black eBay set on my '06, but I totalled the bike 2 weeks later so I can't tell you how well the black held up.
I actually found someone off craigslist parting out his bike and went over and bought a bunch of his screws only. Lol
I bought a fairing bolt kit from amazon, packaged specifically for my model (05 636) for about $20. So far all the bolts I've used held up well and fit good
Pro bolt it is.. Thanks everyone
I was wondering if anyone knows the spec's for the bolt above the gas tank?
Also, I need the spec's for the bolts that hold on the upper fairing on both right and left, a 10 mm bolt works for both sides.
If you're just looking up specs, Procaliber.com has parts diagrams and specs for all the fasteners. I bought all of the fairing bolts from them.
I looked at Pro-Bolts, but I didn't need super fancy, so I went OEM and I love the look. Much better than the cheap non-matching ones I saw on ebay.
1 - 17 of 17 Posts
