1 - 7 of 7 Posts
ok so i know im prob just bein paranoid but my zx6r sounds like its running hard and it has a slight ticking at start up....i just recentley had a full service tune up on it and it had the valves cleaned and adjusted and spark plugs replaced the air filter cleaned and it seems it still sounds like its runin hard!
any ideas or [email protected]?!??!?
See below :p
Reactions: Manolo and ZXNasty
By valves cleaned do you mean checked for tolerance and adjusted as needed cause that is what is normally done. "running hard" is a very vauge term, but the ticking you are talking about could be the CCT. They have a tendency to be finicky on these bikes, especailly on 07-08
they were just put to oem spec and cleaned thoroughly! and what is a cct? sorry been riding for ten years just not a mechanic!
CCT= Cam Chain Tensioner....
the OEM over time gets weak, then the ticking sounds occurs..
2 options:
1 buy another oem CCT
or
2 buy a manual CCT
Reactions: reed12b
Reactions: kawboi11
1 - 7 of 7 Posts
