1 - 3 of 3 Posts
hello all new member here!
my bikes a 2000 zx6r (carbed) with a blue flame can. its run great been to the ring and all over germany on it last month. but reacently (as weather gets colder and wetter) its started to skip a beat every so often and under low throttle imputs it somtimes gives the same symptons as when you have to turn it onto reserve. if you understand? but if you open up the throttle (only when its warmed up properly obviusly) the sympton goes and she pulls just as hard as normal.
any ideas? weather?
any help would be of a great help
many thanks
yannick
could be a few things, air fuel ratio is off, not synced properly, or valve clearance. start with the easier stuff first (adjust air fuel) then go to the valves if the problem persists.
1 - 3 of 3 Posts
