So I was having a charging issue after dropping the bike (stator side). I won’t go into the symptoms, as the issue is now pretty apparent (melted connector pictured).
I did the troubleshooting procedures for the charging system per the manual, and stumbled upon a melted rectifier connector. I’m aware this is not a rare issue, as I’ve spent hours researching similar posts, but I have a couple questions.
1. Does anyone know of connector options, or would I just have to find a similar connector from cycle terminal?
2. Instead of using a connector, should I just hardwire it together after replacing the rectifier? I assume the wiring diagram will show me the proper connections.
3. Is it wise to only swap out the rectifier, without replacing the stator? The stator passed all the voltage tests, but not the resistance test (leads to chassis ground). I have a replacement stator, but prefer not to install it, if it’s unnecessary. If I replace the rectifier and everything works properly, is it still imperative to swap out the stator?
4. Now I’m paranoid about heat affecting the ECU, any recommendations on shielding it? Any ideas on shielding the connectors as well?
I have a new battery also.
