i know!! really strange i must say:rant
neways do u know of any place where i can get this sensor? cause i have no idea what it looks like or called:dowhat
Well If you have no power commander you "map" is ran off of a internal computer for your bike called your ECU. The ecu looks like this
Now if one of you sensors were bad it would either have to be at one of 2 ends.
1)The part that plugs directly into the ECU itself
2)The part that plugs into the injector and other various plugs.
Not sure how to find out which one it is but thinking about it now it seems very, and when I say very I mean not likely at all that, that is the problem. It has to be something else.
Think about it. you have 4 injectors, so 4 plugs. All four of those plugs are ran off of one of the 2 plugs comming off of the ECU so if it was the connector to the ECU then the whole bike fuel injection would be jacked. If it was just one fuel injector connection that would be messed up that whole injector would be jacked and throughout the whole rev cycle, not just 10k+. Make sense. Im gonna do some more research for ya, but let me know what your mods are and what kinda mileage you got on the bike to help me understand!
But im almost positive it has nothing to do with a map sensor unless there is something that I am missing here.
By the way map sensor is pretty generalized there are up to 30+ sensors running of the map to keep everything in check. Kinda make me think he has no clue, but then again im not a bike mechanic just someone who understands them and how to trace problems.
