1 - 3 of 3 Posts
as the title implies.
you need:
-one 96-04 cam chain tensioner(possibly the 05-06 too)
-one tap and die metric or standard(keeping the 11mm diameter,12mm will work too, but 11mm is trouble free)
- one long bolt,nut and aluminum or copper washer
take apart the stock unit, force is necessary to get the keeper pin out.
run your tap of choice throught the tensioner(standard or metric doesn't matter as long as you can get a bolt long enough and the right pitch .If not a blank bolt, with the matching die will make what you need.
this is a simple task really, take your time and get the tap running straight and all will be fine.
and this is what you will end up with..........
1 - 3 of 3 Posts
